16 years agoInterrupt handling
Hi, I connected a counter pin to the PIO in order to generate IRQ every 256 cycles. Appropriate IRQ handler is called after the interrupt triggers. However, after handling the interrupt, the alt_i...
16 years agoHi,
Can you please write how you solved the problem? thanks
