17 years agoInterrupt handling
Hello guys, I got problems with my interrupt routines. One routine is for uart whitch means if a character comes in it'll be stored in a buffer array, the other one is for simple timer ticks. ...
17 years agoHi,
You don't need additional code to enable interrupt, alt_irq_register() routine enables the requested interrupt if ISR pointer is not NULL. You can check for IPENDING register in Nios II CPU for any pending interrupts. Hope this help. :)
