21 years agoInterrupt from external device
Hi from a new member. I've interfaced an external device to Nios II using the "user logic" option. The external device is memory mapped, and the basic interface works OK...using the compon...
21 years agoI used the older "legacy components ->interface to userlogic" and it
works with an external interrupt. I simply setup the interface as following Interface to user logic: PORTNAME WIDTH DIRECTION SHARED TYPE address 8 input yes address write_n 1 input yes write_n read_n 1 input yes read_n data 8 inout yes data chipselect_n 1 input --- chipselect_n irq_n 1 output --- irq_n After updating the symbol in quartus, there is the irq pin on the cpu symbol. I think there seems to be some problems with the new component editor, so perhaps try the old interface. Perhaps somebody from Altera can answer this question, i have read some problems about the new component editor, does it works ???
