20 years agoInterrupt driven UART
Hello everybody, I'm a NIOS II beginner and I'm having trouble in finding an example how to code an interrupt driven UART application where I can send and receive commands from a camera...
20 years agoThis is non HAL code in NIOS1 but it is currently working fine in NIOS2 as well
include # include "excalibur.h" global //Make sure you have a uart in excalibur.h that matches your uart name (na_uartxxxx) np_uart *uart1 = (np_uart *)na_uart_1; init the uart void uart1_setup(void) { //UART 1 setup ----------------------- uart1->np_uartstatus = 0; // clear the interrupt condition nr_installuserisr(na_uart_1_irq ,UART1_ISR,(int)uart1); uart1->np_uartcontrol=0; uart1->np_uartcontrol = uart1->np_uartcontrol | (np_uartcontrol_irrdy_mask); } irq routine void UART1_ISR(int context) { np_uart *uart1 = (np_uart *)context; int status; unsigned char rxChar; status = uart1->np_uartstatus; rxChar = (unsigned char)uart1->np_uartrxdata; uart1->np_uartstatus = 0; // clear the interrupt condition if(status & np_uartstatus_rrdy_mask) // character arrived? { // Write code to handle rxchar; } if(status & np_uartstatus_trdy_mask) // character arrived? { if (more bytes to transmit?) { // Write code to send next byte uart1->np_uarttxdata=next byte } else { // Set the port to read only uart1->np_uartcontrol = np_uartcontrol_irrdy_mask; //only Rx enable (if half duplex) } } } to start a transmit sequence start by sending a byte and then enabling the Tx IRQ flag. uart1->np_uarttxdata=tx1_buffer[0]; // send first byte. IRQ will do the rest uart1->np_uartcontrol =np_uartcontrol_itrdy_mask; // only Tx enable you can have rx irq flag enabled all the time for full duplex. Just write your code to handle it. First use a fix baud rate (as defined in SOPC builder) before playing with your own software settings. Fix baud rates uses less LEs. to test connect the 2 pins (Tx,Rx) either in software or hardware and send a few bytes and return the status with a printf or 2. To make life easier implement a ring buffer for the received character and parse it outside the irq. Don't put too much inside the IRQ routine. Just grab and store. Victor http://www.zerksus.com (http://www.zerksus.com)
