15 years agointernal compiler error in Net-SNMP compilation
Did anyone run into that ? (build env is latest from GIT) ../../net-snmp-5.2.1/snmplib/parse.c: In function 'unload_all_mibs': ../../net-snmp-5.2.1/snmplib/parse.c:4057: error: unrecogniza...
12 years agoHi, How did you build this
nios2-wrs-linux-gnu-gcc (Wind River Linux Sourcery G++ 4.1-176) 4.1.2 tools? Could you give me some a clue ? Although I have build these tools,but the toolchain-build still remind me
/bin/sh: nios2-wrs-linux-gnu-gcc: command not found
Which step do I lost ?
# nios2-linux-gnu-gcc -vUsing built-in specs.
Target: nios2-linux-gnu
Configured with: /opt/nios2gcc4/src/gcc-4.1/configure --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=nios2-linux-gnu --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared --enable-symvers=gnu --enable-__cxa_atexit --disable-nls --prefix=/opt/nios2 --with-sysroot=/opt/nios2/nios2-linux-gnu/libc --with-build-sysroot=/opt/nios2gcc4/install/nios2-linux-gnu/libc --disable-libgomp --enable-poison-system-directories
Thread model: posix
gcc version 4.1.2
# nios2-linux-uclibc-gcc -v
Reading specs from /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/specs
Configured with: /root/buildroot/toolchain_build_nios2/gcc-3.4.6/configure --prefix=/opt/nios2 --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=nios2-linux-uclibc --enable-languages=c,c++ --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-shared --disable-nls --enable-threads --enable-multilib
Thread model: posix
gcc version 3.4.6
# nios2-linux-gcc -v
Thread model: posix
gcc version 3.4.6
Thanks!
