GIrip
4 years agoInternal compiler error - Moving from Nios II SBT 15.1 to 18.1
I have tried to port one of my projects to Nios II SBT 18.1 (working on 15.1). Sadly I got an internal compiler error:
internal compiler error: in gt_ggc_m_S, at ggc-page.c:1483
Code causing the...
hareesh
4 years agoHi,
can you pls share your project files and your version details.
Thanks you,
- GIrip4 years ago
Hi @hareesh,
what are the files you want me to share? Both FPGA and Nios FW projects, with all their related files (in this case a private communication can be better)? OR do you need only something specific like qsys and bsp settings files?
About version details, our target is to move from Quartus Prime 15.1 to Quartus Prime 18.1 (Standard edition):
Quartus Prime 15.1 environment (working properly)
- Quartus Prime Version 15.1.1 Build 189 12/02/2015 SJ Standard Edition
- Altera® Nios® II Classic
- Nios II 15.1 SBT for Eclipse - Nios II Embedded Design Suite Version 15.1.0v20151022-0551
- Eclipse Version Kepler Service Release 2 - Build Id: 20140224-0627
Quartus 18.1 environment (internal compiler error)
- Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Standard Edition
- Nios II 18.1 SBT for Eclipse - Nios II Embedded Design Suite Version 18.1.0v20180913-1045
- Eclipse Version Mars.2 Release(4.5.2) - Build Id: 20160218-0600
Thank you
