20 years agoInterfacing to User Logic
When looking through the altera literature on the SOPC builder there seems to a standard "user logic interface" component, however I don't seem to be able to find it or insantitate it! Also I saw...
20 years ago --- Quote Start --- originally posted by shmueld@Mar 12 2006, 06:29 PM when looking through the altera literature on the sopc builder there seems to a standard "user logic interface" component, however i don't seem to be able to find it or insantitate it! also i saw such a component in one of the sopc builder examples (it appeared different to creating a custom compon http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif ent) but i couldn't find its source. does anyone know how to instantiate this component and how to use it ? i tied different locations in the "component/kit library search path" but had no luck
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13345)
--- quote end ---
--- Quote End --- Interface to "user logic interface" is finding in "Legacy Components" of SOPC Builder The instantiation is so easy like as using it :-) Just add it to system and set up its time parameters and "bus" parameters. "bus" parameters are "what do you need to ouput to world" It means - bit wide of data and address buses, reset signal an etc. Source of this component is generated by "SOPC buldier", it means that you do not find them.
