21 years agointerfacing to custom logic with an interrupt
I have made an interface to custom logic using an avalon slave port with the following signals, clk, irq, readdata, address, read, chipselect the idea is that custom logic c...
20 years agoI don't know if you've got to the bottom of this, but it looks to me like the offending line of code is:
isr_data = *isr_reg_addr; This is accessing your peripheral through the data cache (assuming you have one). It therefore may or may not cause a real access, which may cause you to fail to clear the interrupt. To avoid this problem you should use one of the access macros defined in hal_io.h, e.g.: HAL_READ_UINT32.
