21 years agoInterfacing to a daughter card through PROTO"
Hi. I need to connect to a self-made daughtercard through the proto2 connector on a Nios Development Kit, Cyclone Edition. All the I/O are on the J16 connector. Do I need to enable something special to make it work? Are any of the I/Os on proto2 connected to something else on the development kit? For example: I see the same signal on Y8 on the J16 as on L9 on the J11.
And L9 on J11 is actually H17 if I understood the documentation right. In mnl_nios2_board_cyclone_1c20.pdf pin 35 in J11 is called L9. But if you look through nios_1c20_board_schematic.pdf you'll find that L9 is connected to 1.5 V and that pin 35 is actually H17 which is the same as A00 to the Compact Flash connector. So the documentation is pretty bad. Another example is that in nios_1c20_board_schematic.pdf the signals that go through the buffers is call proto1_IOXX and proto2_IOXX from the FPGA, and at the buffers both are called proto_IOXX and proto5_IOXX after the buffers. This make reading through the documentation pretty bad. But, to my original question again. Are the I/O on proto2 connected to anything else on the board? Ole11 Replies
Yes, I'm sorry but I diddn't check it at all. It was accessed from NiosII web page (http://www.altera.com/products/devkits/altera/kit-nios_1c20.html).
I hope that the boards are the same...
