14 years agoInterface to CFI in Qsys
Hello, I have a Qsys system where I want to implement an interface to Flash which uses a CFI. There seem to be two modules in the Qsys library which can be used as an interface to the Flash. Th...
14 years agoAlso, you may want to check the
Board Update Portal example design. If you install one of the Altera development kit in your PC, you'll see the code.
