20 years agoInterface Issue between Nios(uClinux) & User logic
My user logic is Simple Inverter. The following C - code, which needs to have Read & write transaction with inveter is not Working. Means write is not properly happening. main() { unsigned char *p,*u; int a[100]; volatile int i,k=0,k1=0,k2=0; p = 0x00800050; k = k+1; u = 0x00800054; for ( i = 0; i < 100 ; i++ ) { *p = i; k++;k1++;k2++; // dummy statements a = *u;}
for ( i = 0; i < 100; i++ )
printf(" \n\t data_out: %d ", a); } Here P is the address for Write-port (Corresponding VHDL signal - din) , and U is the address for read-port (Corresponding VHDL signal - dout) But the following code works: main() { unsigned char *p,*u; int a[100]; volatile int i,k=0,k1=0,k2=0; p = 0x00800050; k = k+1; u = 0x00800054; for ( i = 0; i < 100 ; i++ ) { *p = i; k++;k1++;k2++; // dummy statements a = *u;
<span style="color:red">printf(" \n\t data_out: %d ", a); } for ( i = 0; i < 100; i++ ) printf(" \n\t Data_out: %d ", a[i]); }</span> As shown above, keeping a Printf statement is not possible for our application as it is inserting delay. While configuring the User logic connection with Processor, I used Avalon_Slave_0 bus for Reading & Avalon_Slave_1 for writing. And there is no wait cycle kept there. My VHDL code for User Logic is: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Inverter is Port ( clk : in std_logic; reset : in std_logic; cs : in std_logic; wr : in std_logic; din : in std_logic_vector(7 downto 0); rd : in std_logic; dout : out std_logic_vector(7 downto 0)); end Inverter; architecture Behavioral of Inverter is begin process ( cs, clk,reset) begin if (reset = '1') then dout <= "00000000"; elsif ( clk'event and clk = '1') then if( cs = '1' and wr = '1') then dout <= not(din); end if; end if; end process; end Behavioral; So I am looking for a possible solution withoug inserting delay http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
You have to set bit 31 of the p pointer, to uncache the io access.
p = 0x00800050; => p = 0x80800050; - Altera_Forum
Hi Hippo,
Thank You Very Much. That simple mistake created lots of confusion. Finally problem is solved. Regards, K V Naresh
