20 years agoIntel Strataflash P30 and jffs2 problem
Hi Does anyone here have any experience using Intel Strataflash P30 with Nios II? We often get the following error when writing to a mounted jffs2 file system: Node totlen on flash (0x00...
20 years agoI found the answer myself in this mailing list:
mtd/intel p30 flash problem on pxa255 (http://marc.theaimsgroup.com/?l=linux-arm-kernel&m=114833865503774&w=2) The problem was that there is a bug in some Intel P30 256Mbit engineering sample chips with id 0x8922. Here is a patch that fixes the problem:--- ../../../../linux-2.6.16.27-nios/drivers/mtd/chips/cfi_cmdset_0001.c 2006-07-17 15:58:58.000000000 +0200
+++ cfi_cmdset_0001.c 2006-08-28 12:05:38.000000000 +0200
@@ -181,6 +181,17 @@
# endif
+static void fixup_intel_p30(struct mtd_info *mtd, void* param)
+ struct map_info *map = mtd->priv;
+ struct cfi_private *cfi = map->fldrv_priv;
+ struct cfi_pri_intelext *extp = cfi->cmdset_priv;
+ printk(KERN_WARNING "cfi_cmdset_0001: Erasing "
+ "Bit 512 of Feature Set on this P30.\n");
+ extp->FeatureSupport &= ~512;
static void fixup_st_m28w320ct(struct mtd_info *mtd, void* param)
@@ -232,6 +243,7 @@
# endif
{ CFI_MFR_ST, 0x00ba, /* M28W320CT */ fixup_st_m28w320ct, NULL },
{ CFI_MFR_ST, 0x00bb, /* M28W320CB */ fixup_st_m28w320cb, NULL },
+ { CFI_MFR_ANY, 0x8922, /* 28F256P30 */ fixup_intel_p30, NULL },
{ 0, 0, NULL, NULL }
}; Hein
