21 years agoIntel CFI Flash & HAL drivers
Hi, I'm porting some code to our target board which uses the HAL to save settings in Flash. The code works just fine on the Stratix dev. kit board, but fails to program the flash on my targ...
21 years agoRoddy,
You're quite correct I just checked this on one of our test boards. The device code was 0x16 which is intepreted as unlocked. So yes there is a bug which which will on some parts prevent the unlocking of some blocks. That said though the chip programmed happily so there is no generic problem with Strata parts.
