22 years agoInstruction simulator exception
When running a simple program (it prints a few things to stdout) in the Nios II instruction simulator, I see the following console output near the end of the expected output: COSIM: Internal Er...
22 years agoyossarian,
Running your program appears to be generating an internal error in the ISS, hence the unhandled exception error message. Could you try running the canned hello-world example using an altera-provided ptf file eg. /altera/kits/nios2/examples/verilog/stratix_1s10/fast/fast_1s10.ptf to see if that works. It may be the case that your software is inadvertently accessing a peripheral in your system, which is unsupported, thus exposing a bug which is generating the internal error.
