20 years agoInstalling or upgrading cygwin for nios2 5.0
I'd like to upgrade the version of cygwin that came with nios2 5.0. Is this possible? Newer versions of the cygwin dll have fixed a few problems with stty and io redirection. I have read t...
20 years agoHi tns1,
> I'd like to upgrade the version of cygwin that came with nios2 5.0. Is this possible? Not sure. I have some problems when I try to mix the environments. I can use the nios2 binutils, gcc, etc. without problems when building u-boot for example. However, u-boot is completely self-contained (no HAL, uses its own crt0, etc). So far I haven't mustered the time or energy to really dig into this -- since I have cygwin X alongside the Nios II environment just for the X ... I'm a gnome junky ;-) But again, nios2-elf-xxx work fine under the alternate cygwin (and I can at least get some other tools to execute with --help option). I'm pretty sure you could get things working given you can setup the proper environment variables an paths. > I have read that I cannot have a standard cygwin install alongside the custom > cygwin/nios2 install without running into problems. Is this still true with 5.0? I'm using CYGWIN_NT-5.1 1.5.18(0.132/4/2) 2005-07-02 20:30 i686 alongside of Nios II 5.0 without any problems (yet) -- it's just the latest from cygwin.org. Regards, --Scott
