11 years agoInstalling altera 11.1sp2 on ubuntu 14.04LTS
Hi, I have been trying to install altera 11.1sp2 for the past few hours and seem to be getting nowhere. I initially had the same problem as outlined in this thread(http://www.alteraforum.com/forum/showthread.php?t=34368) I have tried both simply typing into the console with the bash ./setup as well as editing the setup file to bash instead of sh. My current problem is as follows:
I enter the following into terminal
~/11.1sp2_259_quartus_free_linux$ ./setup It outputs
Welcome to Altera Software Installer
Copyright (c) Altera Corporation 2011
Starting GUI. If nothing shows up, or you don't have an X display, run:
./setup --help
for commandline usage.
NOTE: All output has been redirected to /tmp/altera_setup.log.HgItAUK044 Nothing shows up. So I then try ./setup --help it returns Traceback (most recent call last):
File "<string>", line 23, in <module>
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 436, in importHook
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 521, in doimport
File "/build/swbuild/SJ/nightly/11.1sp2/259/l32/work/installers/linux32/build/pyi.linux2/altera_installer_cmd/outPYZ1.pyz/cli", line 23, in <module>
File "/build/swbuild/SJ/nightly/11.1sp2/259/l32/work/installers/linux32/build/pyi.linux2/altera_installer_cmd/outPYZ1.pyz/altera_installer", line 34, in <module>
File "/build/swbuild/SJ/nightly/11.1sp2/259/l32/work/installers/linux32/build/pyi.linux2/altera_installer_cmd/outPYZ1.pyz/gui_common", line 18, in <module>
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 477, in importHook
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 495, in doimport
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 297, in getmod
File "/tools/python/2.6.4/linux32/pyinstaller/archive.py", line 468, in getmod
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 109, in getmod
ImportError: /usr/lib/i386-linux-gnu/libfreetype.so.6: symbol png_set_expand_gray_1_2_4_to_8, version PNG12_0 not defined in file libpng12.so.0 with link time reference Sorry if the solution is increadibly obvious im rather bad when it comes to linux I only started using it when I started at uni. Thanks a lot for any assistance you can give me.No RepliesBe the first to reply
