20 years agoInstallation Problem
Hi there, I tried half day to get the uclinux installed on my pc. I am using quartus 5.1 and nios5.1. In the new -> project wizard I cannot find the entry Microtronix Nios II. I read serve...
20 years ago --- Quote Start --- originally posted by miser+mar 17 2006, 08:41 pm--><div class='quotetop'>quote (miser @ mar 17 2006, 08:41 pm)</div>
--- quote start ---
i dont know if all of these are related, but they are good things to check for (based on my personal experience):
- windows with latest patch
- install quartus 5.1 first, nios ii ide 5.1 later. dont change the default directory if not really needed. apply the service packs to both quartus and nios ide.
- then install microtronix stuff. if this still fails..man you have a tough problem because it works on mine.
<!--quotebegin-trapp@Mar 17 2006, 08:16 AM hi there,
i tried half day to get the uclinux installed on my pc. i am using quartus 5.1 and nios5.1. in the new -> project wizard i cannot find the entry microtronix nios ii.
i read serveral post in this forum to get the thing done. none really helped.
i tried:
- from the command prompt in the eclispe directory nios2-ide.exe -clean
- uninstalling microtronics, uninstalling nios, reinstalling
the nios ide worked before and i hope it still does. after that i tried to get it running
on a different pc, this one has installed quartus 5.0 and quartus 5.1. same effect.
from the plugin details button in eclips i can see two plugins
on both mashines:
- microtronix nios ii kernel plugin
- microtronis nios ii linux application plugin
any one more ideas ?
volker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13549)
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=13557)</div> [/b] --- Quote End --- well thanks for reply.... I got it running, but please do not ask me how. I reinstalled serveral times, then I did a complete new download of the zip file ( should be the same ), extracted again, reinstalled and voila it is there. Magic. Thanks Volker
