20 years agoInstallation Problem
Hi there, I tried half day to get the uclinux installed on my pc. I am using quartus 5.1 and nios5.1. In the new -> project wizard I cannot find the entry Microtronix Nios II. I read serve...
20 years agoI dont know if all of these are related, but they are good things to check for (based on my personal experience):
- Windows with latest patch - Install Quartus 5.1 first, Nios II IDE 5.1 later. Dont change the default directory if not really needed. apply the service packs to both Quartus and Nios IDE. - Then install Microtronix stuff. If this still fails..man you have a tough problem because it works on mine. --- Quote Start --- originally posted by trapp@Mar 17 2006, 08:16 AM hi there,
i tried half day to get the uclinux installed on my pc. i am using quartus 5.1 and nios5.1. in the new -> project wizard i cannot find the entry microtronix nios ii.
i read serveral post in this forum to get the thing done. none really helped.
i tried:
- from the command prompt in the eclispe directory nios2-ide.exe -clean
- uninstalling microtronics, uninstalling nios, reinstalling
the nios ide worked before and i hope it still does. after that i tried to get it running
on a different pc, this one has installed quartus 5.0 and quartus 5.1. same effect.
from the plugin details button in eclips i can see two plugins
on both mashines:
- microtronix nios ii kernel plugin
- microtronis nios ii linux application plugin
any one more ideas ?
volker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13549)
--- quote end ---
--- Quote End ---
