12 years agoInstallation of Quartus v13.1 message - "You must install 32 bit "libstdc++" library
I’ downloaded the “Complete Download” : Quartus II Subscription Edition Software (Device support included) Quartus-13.1.0.162-linux-complete.tar After "untaring" and launching “setup.sh” – I’ got the following message: ************************************************************* > ./setup.sh You must install the 32-bit version of the following libraries for the Quartus II installer and software to operate properly: > libstdc++ ... If you proceed with the installation your software may not function correctly. *****************************************************************************************************8 By running the following command: > rpm -q libstdc++ I got: > libstdc++-4.1.2-48.el5 Is there a specific version of libstdc++ that should be installed? Thank you in advance.2 Replies
You have to install the 32-bit compatibility libraries on a 64-bit system. They're distro-specific and should be easy to install. What OS are you attempting to install to?
Hi Ginna
Read the following link: http://rocketboards.org/foswiki/documentation/gsrdgettingstartedyocto Regards, Zs.V.
