21 years agoinstallation of nios II 5.0 Full edition
I installed quartus 5.0 and subsequently Nios II (v?.?) 5.0 full version on a machine with Q4.2 and Nios II v1.1. By default, the installer of Nios is apparently set to install on-top of the ex...
21 years agoI installed5.0sp1 and Nios5.0eval
As noted above, this breaks SOPC builder for previous versions. The environ var fix noted above did NOT fix the problem. I had to un-install Nios5.0. I can still see several environ vars that have been changed for 5.0 and were not restored, but at least SOPC seems to work again.
