21 years agoinstallation of nios II 5.0 Full edition
I installed quartus 5.0 and subsequently Nios II (v?.?) 5.0 full version on a machine with Q4.2 and Nios II v1.1. By default, the installer of Nios is apparently set to install on-top of the ex...
21 years agoThank you Jesse, Soin and BadOmen for the suggestions and clarifications.
May I suggest that Altera changes the installer for Nios II such that it by default installs into a path with a name reflecting the version at hand. Somewhat along the lines indicated by Jesse,<div class='quotetop'>QUOTE </div> --- Quote Start --- c:\altera ...nios2_1.1 ...nios2_5.0 ...quartus2_4.2 ...quartus2_5.0[/b] --- Quote End --- I think Quartus II does it already (...Altera\Quartus5.0), but as mentioned Nios does not. If there can be compatibilty problems from one release to the next this is a helpful feature. Regards,
