21 years agoinstallation of nios II 5.0 Full edition
I installed quartus 5.0 and subsequently Nios II (v?.?) 5.0 full version on a machine with Q4.2 and Nios II v1.1. By default, the installer of Nios is apparently set to install on-top of the ex...
21 years agoOne more thing to be careful with having mulitple installations is that you must make sure your workspaces don't overlap. Also I recommend upgrading your application software to 5.0 by:
1) Create a new system library in 5.0 2) Create a new application project in 5.0 3) Copy over your 1.1 code into your new application project Creating new projects is quick and easy so it should take a minute or two and save you any headaches you may run into.
