21 years agoinstallation of nios II 5.0 Full edition
I installed quartus 5.0 and subsequently Nios II (v?.?) 5.0 full version on a machine with Q4.2 and Nios II v1.1. By default, the installer of Nios is apparently set to install on-top of the ex...
21 years agoYes, the version went from 1.1 --> 5.0 to keep it the same as Quartus. Nios releases are now synchronized with Quartus and this makes it simpler -- one box is shipped to you with the latest release of everything.
As for multiple installations, yes those are allowed and the above post about environment variables is a good suggestion. However, you should be careful to install both Nios & Quartus installations in different folders. For example, my tools are like this: c:\altera ...nios2_1.1 ...nios2_5.0 ...quartus2_4.2 ...quartus2_5.0 just ensure that those are separated. Installing "on top" of an existing folder will probably break things and is not reccomended (the installer should tell you this as well).
