14 years ago
Install Quartus 12.0 in the 64bit of Ubuntu 12.04
1.Download offline version install file and unzip it
https://www.altera.com/download/software/quartus-ii-we
2.Run command
...<your_folder>/12.0_178_quartus_free_linux/altera_installer/bin/altera_installer_gui --gui
3.Select ...<your_folder>/12.0_178_quartus_free_linux/
and Select install target folder (where you want file installed)
4.Manually install 64bit part
cd to ...<your_folder>/12.0_178_quartus_free_linux/linux_installer/quartus_free_64bit/
run install
type your install folder path
choose "n" for not delete installed files
5.Setting USB blaster
Create a new file at /etc/udev/rules.d/51-usbblaster.rules
copy and post
# Altera USB-Blaster rule to set mode to 666. SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
sudo udevadm control --reload-rules
6.setting QUARTUS_ROOTDIR in the shell
export QUARTUS_ROOTDIR="your quartus folder"
That's almust everything about it ....
Also share with google +
Enjoy & Regards,
Kqalea C
