21 years agoinstall.ptf missing
The following error is generated whenever image (happens on ecos and linux) is tried to flash into the nios2 cyclone evaluation board. no install.ptf file found at /cygdrive/u/altera/quartus...
21 years agoI was wrong
The sopc_builder script is already working fine. The only thing that has to be changed is the access-right of java.exe like described above. This seems to be a fault of Nios installation. I was told that this problem will be solved in the next version (5.0) of Nios IDE
