21 years agoinstall.ptf missing
The following error is generated whenever image (happens on ecos and linux) is tried to flash into the nios2 cyclone evaluation board. no install.ptf file found at /cygdrive/u/altera/quartus...
21 years agoI found the solution.
alteras sopc_builder is not correct !
In the perl-file usually located in C:\altera\quartus42\sopc_builder\bin\sopc_builder replace: <div class='quotetop'>QUOTE </div> --- Quote Start --- if (! -x $javax ) { $javax = get_java_exe($sopc_builder . "/bin/jre1.4",$shelled); }[/b] --- Quote End --- by <div class='quotetop'>QUOTE </div> --- Quote Start --- if (! -x $javax ) { $javax = get_java_exe("$quartus_dir"."/bin/jre",$shelled); }[/b] --- Quote End --- Open the Nios IDE shell and execute the following line chmod +x /cygdrive/altera/quartus42/bin/jre/bin/java.exe Now the rebuild should work.
