21 years agoinstall.ptf missing
The following error is generated whenever image (happens on ecos and linux) is tried to flash into the nios2 cyclone evaluation board. no install.ptf file found at /cygdrive/u/altera/quartus...
21 years agojava problems while generating install.ptf
I get the following message when I try to rebuild <div class='quotetop'>QUOTE </div> --- Quote Start --- make -s all Creating C:Documents... sopc_builder: unable to locate Java runtime environment at - line 417. Creating and... sopc_builder: unable to locate Java runtime environment at - line 417. Creating Settingswehrch3b.sopc_builder/install.ptf... sopc_builder: unable to locate Java runtime environment at - line 417.[/b] --- Quote End --- The clean removes install.ptf but the rule for creating it again can has problems while calling 'sopc_builder' <div class='quotetop'>QUOTE </div> --- Quote Start --- my $javax = ""; if ($jre_dir eq "") { $jre_dir = get_quartus_jre($quartus_dir); } if ($jre_dir ne "") { $javax = get_java_exe($jre_dir,$shelled); } if (! -x $javax ) { $javax = get_java_exe($sopc_builder . "/bin/jre1.4",$shelled); } if (! -x $javax ) { die "sopc_builder: unable to locate Java runtime environment"; }[/b] --- Quote End --- On the other hand if I open Quartus and the sopc_builder the install.ptf file is generated correctly. All my colleagues have the same problem. What's wrong in our installation. We use Quartus 4.2 + Service Pack 1 and Nios 1.1.0
