20 years agoInSight debugger instead of Eclipse debugger
Hi All, I would like to know if it is possible to use Insight Debugger Tool (which is also GDB based) , instead of eclipse plug-in provided in NIOS2 IDE ? Because I feel that Eclipse plug-in is ...
20 years ago --- Quote Start --- originally posted by david_cai@Jul 16 2006, 05:13 PM dear all,
i don't clear about how to configuration niosii ide with insight debugger, anyone tell me the detailed information...
thanks very much,
david
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16950)
--- quote end ---
--- Quote End --- I don't think it makes any sense to use the Insight Debugger _with_ the IDE. You either use the IDE's built-in debug facilities or the Insight GDB GUI, but not both...in my opinion. There is nothing special about the Nios II implementation of Insight. You should be able to find plenty of information regarding its use on the web. Cheers, - slacker
