20 years agoInSight debugger instead of Eclipse debugger
Hi All, I would like to know if it is possible to use Insight Debugger Tool (which is also GDB based) , instead of eclipse plug-in provided in NIOS2 IDE ? Because I feel that Eclipse plug-in is ...
20 years ago --- Quote Start --- originally posted by bigboss25+jul 14 2006, 11:37 am--><div class='quotetop'>quote (bigboss25 @ jul 14 2006, 11:37 am)</div>
--- quote start ---
<!--quotebegin-slacker@Jul 14 2006, 08:39 AM it ships as part of the standard gcc toolchain: nios2-elf-insight and/or nios2-debug
i've also used ddd on top of the gdb stuff and it works, as well.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16903)
--- quote end ---
--- Quote End --- Thx a lot Slacker. Just one more question : do you now if the InSight bundled version is the latest one ? Regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16912)</div> [/b] --- Quote End --- Finally, one more question http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif Would it be possible to post files as well as a mini "how to" (may be on Wiki) clarifying usage of DDD with NIOS 2. Thx!
