20 years agoInSight debugger instead of Eclipse debugger
Hi All, I would like to know if it is possible to use Insight Debugger Tool (which is also GDB based) , instead of eclipse plug-in provided in NIOS2 IDE ? Because I feel that Eclipse plug-in is ...
20 years ago --- Quote Start --- originally posted by slacker@Jul 14 2006, 08:39 AM it ships as part of the standard gcc toolchain: nios2-elf-insight and/or nios2-debug
i've also used ddd on top of the gdb stuff and it works, as well.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16903)
--- quote end ---
--- Quote End --- Thx a lot Slacker. Just one more question : do you now if the InSight bundled version is the latest one ? Regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
