22 years agoinittab and rcS
I would like to know if there is an example for writing inittab and rcS. I added Busybox in the filesystem. I would like to enable uart port for the default console. I think that I have to add an entry in this file to enable it. Thanks Christ ian2 Replies
Take a peek inside the Reference Guide. There is an example inittab that can be used.
Also, please be careful with newlines... busybox expects only the linux style newlines. To be safe, I would run each of the files through dos2unix. - Altera_Forum
I copy the 2 files... Is it correct... I don't know why... The console restarts the shell after few seconds
// Here is what it displays ... init started: BusyBox v1.00-pre8 (2004.07.08-18:39+0000) multi-call binary Booting Altera Nios 2 uCLinux expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 Please press Enter to activate this console. # Please press Enter to activate this console. Please press Enter to activate this console. Please press Enter to activate this console. ... // inittab file ::sysinit:/bin/sh /etc/init.d/rcS ::respawn:/bin/agetty -n -l /bin/lsh -L ttyS0 115200 vt100 ::ctrlaltdel:/sbin/reboot ::shutdown:umount –a –r ::restart:/sbin/init ::askfirst:-/bin/sh rcS# !/bin/sh echo "Booting Altera Nios 2 uCLinux" # !/bin/sh# # system startup. # set up the hostname /bin/hostname Nios2 # expand and mount the ramdisk /bin/expand /ramfs.img /dev/ram0 /bin/mount -t ext2 /dev/ram0 /var -n /bin/expand /ramfs.img /dev/ram1 /bin/mount -t ext2 /dev/ram1 /tmp -n # mount proc file system /bin/mount -t proc proc /proc -n # manually assign ip address (uncomment and edit as appropriate)# note: first ifattach (no args) sets local loopback /bin/ifattach# /bin/ifattach --addr 10.1.1.99 --mask 255.255.255.0 --net 10.1.1.0 --gw 10.1.1.11 --if eth0 # try and get ip address automatically...# /bin/mkdir /var/dhcpc# /bin/dhcpcd -NRY & # start up the internet superserver /bin/inetd & # start up the web server /bin/boa & # mount Linux server:# (uncomment and edit as appropriate)# /bin/mount -t nfs 192.168.1.30:/home /mnt/nfs -n -o nolock # mount master ide disk partition(s):# (uncomment and edit as appropriate)# /bin/mount /dev/hda1 /mnt/ide0 -n # that's it... success exit 0 Best regards CHristian
