19 years agoinitramfs Error !
Hi All .
I am new uclinux . I did step by step in nioswiki page but I can't success with toolchain . I got error when "make romfs " --> initramfs error . after make romfs I had romfs dir but the most of subdir in romfs is empty except romfs/etc ---> what wrong ??? I think the reason is uClinux-dist lack file . Ex : I don't have file "linux-2.6.x/usr/.initramfs_data.cpio.gz.d" . I download uClinux-dist-20060803.tar.bz2 + uClinux-dist-20060803-nios2-02.diff.gz + nios2gcc.tar.bz2 at nioswiki page this is message when "make romfs" ...... romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_SHADOWPASSWDS -s config/shadow /etc/shadow for i in uClibc /home/vietluong/Nios/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done /bin/sh: nios2-elf-gcc: command not found /bin/sh: nios2-elf-gcc: command not found /bin/sh: nios2-elf-gcc: command not found make[2]: Entering directory `/home/vietluong/Nios/uClinux-dist/uClibc' [ -e /home/vietluong/Nios/uClinux-dist/romfs/lib ] || mkdir /home/vietluong/Nios/uClinux-dist/romfs/lib /bin/sh: nios2-elf-gcc: command not found if [ "" ]; then romfs-inst.sh /lib/lib.so; fi make[2]: Leaving directory `/home/vietluong/Nios/uClinux-dist/uClibc' make[1]: Leaving directory `/home/vietluong/Nios/uClinux-dist/lib' make[1]: Entering directory `/home/vietluong/Nios/uClinux-dist/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/home/vietluong/Nios/uClinux-dist/include' make[1]: Entering directory `/home/vietluong/Nios/uClinux-dist/user' for i in boa busybox cgi_generic dhcpcd-new fdisk ftp ftpd-new games inetd init mount sash telnetd /home/vietluong/Nios/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entering directory `/home/vietluong/Nios/uClinux-dist/user/boa' for i in src ; do make -C $i romfs || exit ; done make[3]: Entering directory `/home/vietluong/Nios/uClinux-dist/user/boa/src' romfs-inst.sh /bin/boa cp: cannot stat `boa': No such file or directory make[3]: *** [romfs] Error 1 make[3]: Leaving directory `/home/vietluong/Nios/uClinux-dist/user/boa/src' make[2]: *** [romfs] Error 2 make[2]: Leaving directory `/home/vietluong/Nios/uClinux-dist/user/boa' make[1]: *** [romfs] Error 2 make[1]: Leaving directory `/home/vietluong/Nios/uClinux-dist/user' make: *** [romfs.subdirs] Error 1 Please help me !!! thanks .2 Replies
You only need to create the directory boa to bypass this error.
mkdir ~/Nios/uClinux-dist/romfs/bin/boa - Altera_Forum
--- Quote Start --- originally posted by marhm@Nov 22 2006, 04:22 PM you only need to create the directory boa to bypass this error.mkdir ~/nios/uclinux-dist/romfs/bin/boa
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19581)
--- quote end ---
--- Quote End --- Hi All ! My problem is solve . I just want tell little : I got some foolish error and the reason is my machine Thanks All for help me ! thanks again .
