12 years agoiniche memory access between hardware and nios cpu
New here and am having a problem with the iniche stack and the simple socket server. When I see a new tcp session initiated to the simple socket server, i write off the contents of that first packet...
12 years agoThe settings can be modified by in the Qsys system. You can access the settings wizard in an existing Qsys system by double-clicking on the instance in Qsys. In a new system, you have access to the wizard when you instantiate the component.
