19 years agoInformation about HAL of device driver
Hi, i would like to write a software for a Nios II. Where can i find more information about function of the device drivers expect for the header file. I will write a test for a CFI flash memory. ...
19 years ago --- Quote Start --- originally posted by nero4444@Apr 2 2007, 02:17 PM hi,
i would like to write a software for a nios ii. where can i find more information about function of the device drivers expect for the header file. i will write a test for a cfi flash memory. i created my system in the sopc builder and use the altera_avalon_cfi_flash.h in the nios ide. the description is not helpful in the altera_avalon_cfi_flash.h.
thank you in advance!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22738)
--- quote end ---
--- Quote End --- Maybe it was self-evident for you, that you read that already, but if not, check the Altera manual for information: http://www.altera.com/literature/lit-nio2.jsp: (http://www.altera.com/literature/lit-nio2.jsp:) Nios II Software Developer's Handbook ->Section II. The HAL System Library ->Chapter 5. Developing Device Drivers for the HAL (ver 7.0.0, Mar 2007, 253 KB)
