22 years agoInfo on add_edit_ui WIZARD_UI PTFs?
--- Quote Start --- originally posted by altera sopc builder ptf file reference manual page 65 CLASS <class_name>/USER_INTERFACE/WIZARD_UI[/b] [...] The contents of a WIZARD_UI section is ou...
22 years agoHere's what I've got so far:[list][*]What effect does a DEBUG {} block have? I've seen it in a couple of places.
[*]What is the format for the WAVEFORM/ITEM/value field? [*]What is the Europa library that you use to generate your Perl module-generation scripts? [*]What language is used between the {{ }} delimiters in strings? [/list]More questions later, I'm sure...
