20 years agoInfamous Verify Failed
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif Well - as with many other people from what I've read - I get the old verify failure message when trying to download ...
20 years ago --- Quote Start --- originally posted by lemonoje@Feb 3 2006, 03:13 PM great - glad you found the problem! that will probably also get rid of the jitter warning error that you get when it has to route internal
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12529)
--- quote end ---
--- Quote End --- Hi lemonoje i'm getting started now with a stratix II (EP2S60F1020C4) and i had the same problem : Verifying 03000020 ( 0%) Verify failed Leaving target processor paused. I solved it by downloading an the board the standard.qpf file that i found i the directory: altera\kits\StratixII_DSP_Kit-v1.1.0\Examples\HW\NiosII\example_designs\vhdl\standard I have downloaded this file without compiling it. I started Nios II IDE and runned a sample project unchecking Validate Nios II System ID before software downolad. Everything works fine now.Good Luck and sorry if said uncorrect things but i'm not so expert as you are! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
