20 years agoInfamous Verify Failed
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif Well - as with many other people from what I've read - I get the old verify failure message when trying to download ...
20 years ago --- Quote Start --- originally posted by liangyi@Jan 19 2006, 02:36 AM hi lemonoje,
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
the memory in terms of timing works fine because i tested it using labview making calls to fs2's mdi to perform adderss/data bus tests, etc... --- Quote End --- But, how do you get the sdram pins work fine? The IDE display download info, then verify failed. Do you know that what will be done in verify process and what is the sdram pins state? Thank you, LiangYi <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12281)</div> [/b] --- Quote End --- I'm sorry I have no idea what you're asking.
