20 years agoInfamous Verify Failed
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif Well - as with many other people from what I've read - I get the old verify failure message when trying to download ...
20 years agoHi lemonoje,
<div class='quotetop'>QUOTE </div> --- Quote Start --- The memory in terms of timing works fine because I tested it using LabVIEW making calls to FS2's MDI to perform adderss/data bus tests, etc...[/b] --- Quote End --- But, how do you get the sdram pins work fine? The IDE display download info, then verify failed. Do you know that what will be done in verify process and what is the sdram pins state? Thank you, LiangYi
