20 years agoInfamous Verify Failed
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif Well - as with many other people from what I've read - I get the old verify failure message when trying to download ...
20 years agoIf you have problems with downloading programs from the IDE, I suggest to try reconfigure your FPGA with a "simple" test design that is a sub-set of your design. For example to isolate if your problem is SDRAM or SRAM, try to use/add onchip_memory to run hello world from. If the onchip_memory program runs, but loading the program to SDRAM/sram still fails, I would take a closer look at the memory timing or phase setting.
Once feature I've found useful in sorting out a "verify failure" is to have a System ID peripheral (this is found in the SOPC Builder "other" components group) in my system design. This will sort out if I accidentally loaded the wrong system on my development board or if the board gets reset into a "safe" design on a NIOS II dev board. When I download a program to a board, if I have the wrong system loaded it will flag a different time stamp. Another useful part of this is if the system ID tag is something odd like FFFF_FFFF, it shows that I could have a hardware issue like: 1) some setting error in my design that is messed up my system like I forgot to set "unused IOs to tri-state" (by default Quartus II will set all unused IOs to drive ground which may cause issues with other componets on the board that are not expecting the FPGA to pull its pins to ground). 2) line noise and my JTAG port needs a pull-up resistor/cap on a signal to handle line noise or I could have a bad USB-blaster etc.... Good luck in isolating the problem
