20 years agoInfamous Verify Failed
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif Well - as with many other people from what I've read - I get the old verify failure message when trying to download ...
20 years agoWell, the memory interface is a straight SDRAM instantiated in SOPC and then all the signals are routed to the chip. The memory in terms of timing works fine because I tested it using LabVIEW making calls to FS2's MDI to perform adderss/data bus tests, etc...
Everything works doing basic R/W peek/pokes from the FS2 CLI. Thanks for the feedback. Any other ideas? PS - I am also getting Verify Failed from the Nios II flash programmer (from the sdk shell) when trying to load flash. I even tried re-installing Nios II 5.1 - no luck.
