16 years agoinetd or ftpd does not display file listing of directory
Hi, All! I use inetd & (how it is written in nioswiki) and the ftpd service work fine (about 2-2.5MB/s), but i am not able to perform dir or list - listing files of actual directory. Could yo...
16 years ago --- Quote Start --- I have ls in /bin, but it is only link .... but when i use busybox, every commands, which i add in busybox, are links. --- Quote End --- All busybox generated commands are links to busybox. That is the "busybox trick". You don't need to bother, it just works (though slow, see the Wiki on "Haserl"). --- Quote Start --- Dont work in sash or msh shell, why ? --- Quote End --- I don't understand what you mean. --- Quote Start --- Like ftp client use totalcommander. --- Quote End --- You might try some decent Linux program, too, but of course TotalCommander should work if ls is decently enabled. -Michael
