13 years agoincreasing performance of nios 2
Hallo, Is there any possibility to increase the performance of nios II in C4 related to the debug configuration? I know this from some µCs the there is a big increase by disabling the debug ...
13 years agoThe JTAG debug doesn't affect the execution time of normal code.
For best performance: - Make sure you compile everything (including the BSP/C library) with -O2 or -O3. - Don't use floating point. - Don't use printf. - Try to use as little of the C libarary as possible. - Fit all your code and data into tightly coupled memory. - Don't use Altera's alt_main() code unless you really need the stdio setup and teardown (forces malloc() and friends into your image). - Use the 'small data' segment (%gp relative addressing) for as much data as possible. - Write C very carefully to give the compiler the best chance of optimising the code.
