20 years agoincrease sdram size on nios dev kit
Hi nios experts, I have an altera niosII 2s60 dev kit and those came with 16Mbytes of sdram (1 chip). Has anyone tried to swap this with a larger sdram chip? Anyone see a problem with just dropp...
20 years agoJust an update.
I installed a pin-4-pin compatible part for the sdram (MT48LC8M32B2TG) and all is good. I now have 32 MBytes of ram to play with instead of the default 16MBytes.. Had to do as Mike suggested, changing the sdram setting inside sopc builder and rebuilding the entire project. Process was relatively easy overall. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
