20 years agoincrease sdram size on nios dev kit
Hi nios experts, I have an altera niosII 2s60 dev kit and those came with 16Mbytes of sdram (1 chip). Has anyone tried to swap this with a larger sdram chip? Anyone see a problem with just dropp...
20 years agoIf you get a chip which is completely pin-compatible, then all you need to do is change the parameters in the SDRAM peripheral in your SOPC Builder system to match the new chip. Caveat engineer, though; if it doesn't work, you're on your own.
