11 years agoIncompatible SD-Cards
I have tried to prepare a new SD-card and I ran into a problem: - I use the Socrates-board - I have used the image from the website (socrates-training.tgz) - The SD-card was prepared on different Linux-PCs (Ubuntu in VM, Ubuntu on Microserver) - The SD-card was connected with a USB-to-SD-adapter (Transcend) - The script was running with success When I install the SD-card in the socrates-board, nothing happens.. This was reproducible with two SD-cards: - Transcend 8GB, SDHC, Class 4 With the SD-card, shipped with the Socrates-board, everything is fine, but this is the same card, but another supplier: - Toshiba 8GB, SDHC, Class 4 When I use another Transcend-card, it works also: - Transcend 16GB, SDHC, Class 10 Is this a known issue? Thanks and best regards, JoAs1 Reply
Is the problem still happen If create via window system?
