20 years agoIncluding external libraries
I would very really like to include the public Crypto++ library into my NIOS system. Is this possible? Any hints?
I need to deal with BIG integers (2048bit) for RSA and I'm at a loss Thanks!1 Reply
Pretty generic question, however, you could try downloading the software onto your workstation and seeing if it will compile natively under Cygwin (or Linux). Typically these packages have a "configure" script which will auto-setup the build process for you, after which you can run "make". If this works, then you can drag the sources into the Nios II IDE, after setting up a managed software library project.
I've done this in the past, seemed to work just fine with an MPEG library I was playing around with. Sorry to be soooo vague with the answer. Either PM me or post more details on what you're doing. Cheers, Chris --- Quote Start --- originally posted by mike_r@Jun 22 2006, 09:30 AM i would very really like to include the public crypto++ library into my nios system. is this possible? any hints?i need to deal with big integers (2048bit) for rsa and i'm at a loss
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16338)
--- quote end ---
--- Quote End ---
