15 years agoIncludes.h no such file or directory
I am using NIOS II 10, and i am using in my code includes.h. The problem is that while compiling the nios couldnt discover or find the path of the includes.h... so i tried to add manually ...
12 years agoI had the similar problem. I forgot to select RTOS. To do this
Right click project -> System Library Properties Here you can select an RTOS from dropdown.
