15 years agoIncludes.h no such file or directory
I am using NIOS II 10, and i am using in my code includes.h. The problem is that while compiling the nios couldnt discover or find the path of the includes.h... so i tried to add manually ...
15 years agoi asked the one who created the project and he sent me the ucos_ii.h and os_cfg.h and i found that they are the same like mine. He told me that he didnt include any path for his project. BUT for me i had to add the files manually to remove the errors.
SO it is really weird that we have the same files and everything and i have thses c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_arg_chk_en: enable (1) or disable (0) argument checking" blank_project_mah line 1783 1286796718005 919c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_cpu_hooks_en: uc/os-ii hooks are found in the processor port files when 1" blank_project_mah line 1788 1286796718005 920
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_debug_en: allows you to include variables for debugging or not" blank_project_mah line 1798 1286796718005 921
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_flag_en: enable (1) or disable (0) code generation for event flags" blank_project_mah line 1438 1286796718005 896
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_lowest_prio: defines the lowest priority that can be assigned" blank_project_mah line 1803 1286796718005 922
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_max_events: max. number of event control blocks in your application" blank_project_mah line 1808 1286796718005 923
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_max_tasks: max. number of tasks in your application" blank_project_mah line 1642 1286796718005 902
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_mbox_en: enable (1) or disable (0) code generation for mailboxes" blank_project_mah line 1480 1286796718005 897
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_mem_en: enable (1) or disable (0) code generation for memory manager" blank_project_mah line 1514 1286796718005 898
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_mutex_en: enable (1) or disable (0) code generation for mutex" blank_project_mah line 1540 1286796718005 899
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_q_en: enable (1) or disable (0) code generation for queues" blank_project_mah line 1562 1286796718005 900
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_sched_lock_en: include code for osschedlock() and osschedunlock()" blank_project_mah line 1817 1286796718005 924
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_sem_en: enable (1) or disable (0) code generation for semaphores" blank_project_mah line 1612 1286796718005 901
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_change_prio_en: include code for ostaskchangeprio()" blank_project_mah line 1675 1286796718005 907
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_create_en: include code for ostaskcreate()" blank_project_mah line 1679 1286796718005 908
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_create_ext_en: include code for ostaskcreateext()" blank_project_mah line 1683 1286796718005 909
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_del_en: include code for ostaskdel()" blank_project_mah line 1687 1286796718005 910
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_idle_stk_size: idle task stack size" blank_project_mah line 1659 1286796718005 903
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_name_size: determine the size of task names" blank_project_mah line 1691 1286796718005 911
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_profile_en: include data structure for run-time task profiling" blank_project_mah line 1827 1286796718005 925
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_query_en: include code for ostaskquery()" blank_project_mah line 1699 1286796718005 913
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_stat_en: enable (1) or disable(0) the statistics task" blank_project_mah line 1663 1286796718005 904
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_stat_stk_chk_en: check task stacks from statistics task" blank_project_mah line 1671 1286796718005 906
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_stat_stk_size: statistics task stack size" blank_project_mah line 1667 1286796718005 905
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_suspend_en: include code for ostasksuspend() and ostaskresume()" blank_project_mah line 1695 1286796718005 912
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_sw_hook_en: allows you to include the code for ostaskswhook() or not" blank_project_mah line 1832 1286796718005 926
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_tick_step_en: allows to 'step' one tick at a time with uc/os-view" blank_project_mah line 1837 1286796718005 927
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_ticks_per_sec: sets the number of ticks in one second" blank_project_mah line 1709 1286796718005 914
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_dly_hmsm_en: include code for ostimedlyhmsm()" blank_project_mah line 1713 1286796718005 915
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_dly_resume_en: include code for ostimedlyresume()" blank_project_mah line 1717 1286796718005 916
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_get_set_en: include code for ostimeget() and ostimeset()" blank_project_mah line 1721 1286796718005 917
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_tick_hook_en: allows you to include the code for ostimetickhook() or not" blank_project_mah line 1842 1286796718005 928
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_tmr_en: when (1) enables code generation for timer management" blank_project_mah line 1731 1286796718005 918
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h error: `os_lowest_prio' undeclared here (not in a function) blank_project_mah line 736 1286796718005 893
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h error: `os_max_tasks' undeclared here (not in a function) blank_project_mah line 756 1286796718005 895
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h error: `os_task_idle_stk_size' undeclared here (not in a function) blank_project_mah line 748 1286796718005 894
so maybe there is smth in the options of the project...i dont really know... Does anyone know what to do or try??
