15 years agoIncludes.h no such file or directory
I am using NIOS II 10, and i am using in my code includes.h. The problem is that while compiling the nios couldnt discover or find the path of the includes.h... so i tried to add manually ...
15 years ago --- Quote Start --- the project that i am working on is already existed and tested. i just want to open, build, and then run it on my pc to see the output. --- Quote End --- Then that project should have it's own local uC/OS-II files and an OS_CFG.h already configured. If as you say you have a project already done then it should still build now unless the files that are# included are not the same. Search for other OS_CFG.h files. Bill A
