14 years agoInclude Library in project
Hi all, because I couldn't find anything on the net so far, I'm posting my problem here. I'm trying to pack parts of my NIOS-Code as a library and include it in another project using following d...
13 years agoOK,
The secret seems to be as follows : 1) Use Eclipse to edit the Makefile - that way you will get the right copy. 2) create a directory lib and put the library libaplc.a into it, then set : ALT_LIBRARY_DIRS := lib 3) set : ALT_LIBRARY_NAMES := aplc 4) set : ALT_LDDEPS := D:\home\jbww\Design\Altera\Eclipse_v12\NiosProjects\aplc_matrix\lib\libaplc.a I have had to simplify the I/O for the moment, but I can now translate Apl to c using aplc., and have it compile and run on the DE1 board : The same partially gutted library source compiles OK on the Altera NiosII. Here is a simple set of matrix operations in a function "matrix": Source in AplX: matrix 'A:' A ← ⍳ 5 A ' ' 'B:' B ← ⍳ 9 B ' ' 'C: inner product:' C ← A ∘.× B C ' ' 'T: transpose:' T ← ⍉ C T ' ' 'O: outer product (matrix multiply):' O ← C +.× T O ' ' 'S: solve matrix:' S ← C ⌹ A S NiosII simple floating point soft processor, on a Terassic DE1 development board : A: 1 2 3 4 5 B: 1 2 3 4 5 6 7 8 9 C: inner product: 1 2 3 4 5 6 7 8 9 2 4 6 8 10 12 14 16 18 3 6 9 12 15 18 21 24 27 4 8 12 16 20 24 28 32 36 5 10 15 20 25 30 35 40 45 T: transpose: 1 2 3 4 5 2 4 6 8 10 3 6 9 12 15 4 8 12 16 20 5 10 15 20 25 6 12 18 24 30 7 14 21 28 35 8 16 24 32 40 9 18 27 36 45 O: outer product (matrix multiply): 285 570 855 1140 1425 570 1140 1710 2280 2850 855 1710 2565 3420 4275 1140 2280 3420 4560 5700 1425 2850 4275 5700 7125 S: solve matrix: 1 2 3 4 5 6 7 8 9 cheers, Beau Webber
